am 02.10.2019 23:23
Hello,
My cable Internet used to be relatively slow recently but now it is very very slow. My contact is Red Internet & Phone
200 Cable, but speed tests, either by Vodafone speed test software or another software, only show that my line currently have the capacity of 5mbit/sec ![]()
Is there an explanation for that and how can I solve this???
Cheers,
Ahmed
am 02.10.2019 23:24
am 04.10.2019 19:45
Two days with no response! The service become too bad aday after another.
Instead of reaching 200 mbit/second, I only get less than 5% of it (2-5 mbit/second) for the same price!!!
Any solutions? The telephone helpline is only in German and is very unfriendly. Could you please consider some more attention to your customers???
am 04.10.2019 19:46
Hi, Ahmed,
is the speed so low only via WiFi? What is the speed when you do speed tests in the morning or evening?
Regards
Wallace
am 04.10.2019 19:53
Thanks wallace for your reply.
The same low speed happens in the morning and during night. It was like this for quite long time, but recently it becomes horrible. Please see attached image for a speed test I just have.
I only checked the speed through WiFi as I do not use cables. I notice that tge upload speed seems to be okay, but the download is the problem I think.
04.10.2019 20:13 - bearbeitet 04.10.2019 20:14
am 06.10.2019 12:37
Any suggestions or solutions??
am 07.10.2019 14:27
Hello mido2,
what wifi-settings did you use? which router did you get from us and can you check the usage of the wifi channel?
Regards
Jens
am 07.10.2019 23:15
am 07.10.2019 23:16
How can I check the usage of the wifi channel?
