am
18.08.2019
15:13
- zuletzt bearbeitet am
18.08.2019
15:20
von
Seb4sti4n
Since 18.08.2019 at 1-2 PM my Internet and phone connection are gone.
I tried the 2 following steps.
Step 1:
- The message says reconnect the DSL cable but the DSL cable is correctly connected
- The message said "Push the button reconnect to restore the connection" or something like this. I clicked but nothing changed
Step 2: I tried a reset of the router to make the full activation process. But the activation process is stuck at the point where the screen asks to plug the DSL cable in the right place but it is already there. I tried in and out, still the same. Sometimes, the screen says "trying to connect to Vodafone network". No success
The only green light in the modem is WLAN, the other ones are switched off (MOBIL Telefon Internet)
Here are the details
IT was not possible due to my poor German to correctly communicate with the hotline
Edit: @Volaristo Move Thread from Cable to DSL. Best Regards, Sebastian
am 18.08.2019 17:51
The problem is solved. Suddenly, it was possible to activate the line and now the connection is fully back. I guess there was a technical issue on the network.
am 18.08.2019 15:54
Could an English speaking technician allow me to send him or her or necessary details? Orally with the hotline I am definitely not able to understand German (although I can explain) so we stopped the conversations.
am 18.08.2019 17:51
am 19.08.2019 10:37
Hi Volaristo,
I'm happy that you can use your DSL connection again.
I will close this thread.
Regards,
Jens
