An error occured! templates/dsl-kabel/_help.html (No such file or directory) java.io.FileNotFoundException: templates/dsl-kabel/_help.html (No such file or directory) at java.base/java.io.FileInputStream.open0(Native Method) at java.base/java.io.FileInputStream.open(FileInputStream.java:213) at java.base/java.io.FileInputStream.(FileInputStream.java:152) at clojure.java.io$fn__11655.invokeStatic(io.clj:232) at clojure.java.io$fn__11655.invoke(io.clj:232) at clojure.java.io$fn__11607$G__11561__11614.invoke(io.clj:72) at clojure.java.io$fn__11629.invokeStatic(io.clj:168) at clojure.java.io$fn__11629.invoke(io.clj:168) at clojure.java.io$fn__11568$G__11557__11575.invoke(io.clj:72) at clojure.java.io$reader.invokeStatic(io.clj:105) at clojure.java.io$reader.doInvoke(io.clj:89) at clojure.lang.RestFn.invoke(RestFn.java:413) at clojure.lang.AFn.applyToHelper(AFn.java:154) at clojure.lang.RestFn.applyTo(RestFn.java:135) at clojure.core$apply.invokeStatic(core.clj:669) at clojure.core$slurp.invokeStatic(core.clj:7089) at clojure.core$slurp.doInvoke(core.clj:7089) at clojure.lang.RestFn.invoke(RestFn.java:413) at sc.vodafone.website.pages.may22.templates$render.invokeStatic(templates.clj:10) at sc.vodafone.website.pages.may22.templates$render.invoke(templates.clj:6) at sc.vodafone.website.nav$render.invokeStatic(nav.clj:118) at sc.vodafone.website.nav$render.invoke(nav.clj:106) at sc.vodafone.website.html_export$nav_page.invokeStatic(html_export.clj:29) at sc.vodafone.website.html_export$nav_page.invoke(html_export.clj:25) at clojure.lang.AFn.applyToHelper(AFn.java:154) at clojure.lang.AFn.applyTo(AFn.java:144) at clojure.core$apply.invokeStatic(core.clj:667) at clojure.core$apply.invoke(core.clj:662) at shadow.server.http.core$call_handler.invokeStatic(core.clj:161) at shadow.server.http.core$call_handler.invoke(core.clj:158) at sc.vodafone.website.html_export$http_root.invokeStatic(html_export.clj:52) at sc.vodafone.website.html_export$http_root.invoke(html_export.clj:50) at clojure.lang.AFn.applyToHelper(AFn.java:154) at clojure.lang.AFn.applyTo(AFn.java:144) at clojure.core$apply.invokeStatic(core.clj:667) at clojure.core$apply.invoke(core.clj:662) at shadow.server.http.core$call_handler.invokeStatic(core.clj:161) at shadow.server.http.core$call_handler.invoke(core.clj:158) at sc.vodafone.website$root.invokeStatic(website.clj:656) at sc.vodafone.website$root.invoke(website.clj:650) at shadow.server.http.core$do_request.invokeStatic(core.clj:840) at shadow.server.http.core$do_request.invoke(core.clj:836) at shadow.server.http.core$do_ring.invokeStatic(core.clj:858) at shadow.server.http.core$do_ring.invoke(core.clj:844) at sc.vodafone.system$get_ring_handler$fn__28838.invoke(system.clj:420) at ring.middleware.file$wrap_file$fn__28579.invoke(file.clj:50) at ring.middleware.content_type$wrap_content_type$fn__28613.invoke(content_type.clj:34) at org.httpkit.server.HttpHandler.run(RingHandler.java:91) at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:572) at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:317) at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1144) at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:642) at java.base/java.lang.Thread.run(Thread.java:1583)
Niedrige Internetgeschwindigkeit, großer Ping in CS: GO
ukaszim1
  • Jaki masz kontrakt- Internet
  • Z korzystania modemu / routera korzystasz? - CBN  CH7466CE
  • Czy korzystasz z wypożyczonego urządzenia od nas, czy masz własny urządzenie ? -   Urządzenie pożyczkowe
  • Który błąd występuje? zbyt niska prędkość; Packetloss Codziennie od 17:00 do północy
  • Jak jest twój terminal z modemem podłączonym ? - LAN
  • Jakiej przeglądarki zazwyczaj używasz? Chrome
  • Jaki system operacyjny masz na swoim komputerze? Windows 10
  • Początek i okres przejściowy Zmniejsz prędkość od początku umowy wieczorem. Bardzo niska prędkość wieczorem od 2 tygodni. Nigdy nigdy nie możesz grać w gry online
  • Prześlij zrzut ekranu wartości sygnału . Można korzystać z interfejsu użytkownika routera kablowego za pomocą  192.168.0.1 lub 192.168.178.1 we Fritzbox.
  • Jakie środki podjęto infolinia DOSTĘPNE (dostępny pod numerem 0800-5266625)?
  • W jakim stanie mieszkasz? - Bayern
    Gram popularny w CS: GO - tam ping jest ponad 80+ od późnego popołudnia do późnego wieczora, co nie jest miłością w tej grze.
    Przyjaciel, który mieszka blisko mnie, wciąż ma 400 MB / si 25 MB / s
15 Antworten 15
We can communicate in English
Stephan
Hi ukaszim1,
perfect, in English then. Smiley (fröhlich)
Since we can't read your first post here, I'd like to ask you to explain it again briefly in English.
When and at what times do the upload problems occur most frequently? Do you just use our hardware or additional devices (Routers, Switches, e.g.). Are you connected via LAN or WLAN?
And last but not least: Please send me a private message with the following information:
your name
your address
date of birth
your customer number
the link of this thread
Please reply here when you have sent the private message.
Regards
Stephan
Wysłałem PM and thank you for the reaction
Stephan
Hi ukaszim1,
thanks for the PM.
Please also answer the other questions, i.e. whether you use other devices, LAN or WLAN and so on.
Thanks and regards
Strephan
I have a computer connected via LAN and other phones, a tablet via WIFI.
I even tried to disable wifi on mobile devices and it still didn't work. I am sending a picture of the internet and now I am happy. Speed (mainly upload) will decrease significantly in the evening
Stephan
Hi ukaszim1,
thanks for that.
The picture is  from 1 p.m. and it looks good. At what time do the problems start in the afternoon?
Regards
Stephan
