am 19.01.2020 22:16
I received my router last 15th January and I did install the router as guided and the internet does not work, so I contacted customer care with the help of my friend because I can't speak german, Once they have heard the issue they said its should work out of the box. And then they have sent me another router again yesterday 18th January, which has the same issue, unfortunately. I don't know what to do anymore, it's so hard to reach customer service because of the language barrier and no one replies to emails. Could someone please send a technician and get this over with? I'd really appreciate if someone could help with this immediately.
am 23.01.2020 18:00
I am pleased that the installation was completed so quickly. I have booked the WiFi option for you.
Regards
Wallace
am 20.01.2020 19:55
Hi Dilusha,
I like to check and see why the line's not working. Please send me your customer data (name, address, customer number, birthday) in a private message and let me know that you have sent the data.
Regards
Wallace
am 21.01.2020 16:35
Hi Wallace,
Thanks, I have PM'd you my details as requested, appreciate your help on this.
am 21.01.2020 17:49
Hi Dilusha,
A technician must install the connection on site. Do you agree with a technician and can you provide access to the house system?
Regards
Wallace
am 21.01.2020 17:53
Yes Ineed, Please send a technician, I can talk with housemeister to arrange checking the system. Could the technician come tomorrow ?
am 21.01.2020 19:01
The technician will contact you soon to make an appointment.
Regards
Wallace
am 23.01.2020 10:21
Thanks a lot, the technician came and fixed the problem with the cable, but he said I will still need to enable the WiFi option. So tried activating the WiFi option (2.99 Euro ) via the customer portal, but it gives me an error. Could you please activate this for me?
am 23.01.2020 11:07
Its not working, I think the issue is that I can't get the WiFi option enabled. Could you please enable it for me?
am 23.01.2020 18:00
Regards
Wallace
am 23.01.2020 23:42
Thank you very much, problem resolved.
