am
21.06.2017
09:44
- zuletzt bearbeitet am
21.06.2017
09:53
von
Der Ritter
Hallo.
I have no DSL connection since yesterday 20.06. I'm located in 64293 Robert-Bosch-Strasse. Please help
Habe seit gestern den 20.06.17 kein Netz (DSL). Betrifft in 64293 Robert-Bosch-Strasse.
Masoud
Edit: As there is no correlation between the issue posted and the board section "Mein Vodafone & Email", I will move this thread accordingly, @maxxkia.
am 22.06.2017 13:03
Hi maxxkia,
welcome to the Vodafone Community!
In order to open a technical ticket for you, please send me a private message (click on my avatar -> Diesem Benutzer eine private Nachricht senden)
I need your name, your customer number and a mobile phone number, so the technicians can call you back and/or send you SMS.
Thanks.
Regards,
Jens (Moderator)
am 21.06.2017 09:55
Have you already given the self-help hints and tipps a try, @maxxkia?
Also, your information is rather meagre. Mind checking this post and adding the required input to make helping you easier? Thanks.
Ein Klick auf "Danke" tut nicht weh - ich sage schon mal "Dankeschee!" ![]()
Achtung, es folgt eine Signatur: Wenn überhaupt, dann jammern wir auf einem extrem hohen Niveau.
am 22.06.2017 11:06
I tried the steps in self-help page, I also did a factory reset but it's not fixed. I got FC811 code in the diagnostic section. Now after I've done factory reset I can not setup the modem because it says I should connect the DSL cable, but it's already connected I don't know what is the problem. Probably my model is broken which is a bit surprising since I got this EasyBox-804 last October or November.
I called the help service but the staff who answered the phone didn't speak English she told me a colleague who speaks English should call me. I haven't got any calls since 9:00 yet.
am 22.06.2017 13:03
Hi maxxkia,
Thanks.
Regards,
Jens (Moderator)
