am 26.07.2018 16:02 - zuletzt bearbeitet am 27.07.2018 13:33 von Jens-K
Hi Vodafone,
I couldn't reach anyone by phone because my German is really bad, so my problem is that my internet doesn't work. I checked the cables and everything looks normal. On the router, It shows green until internet icon, then It restarts to check. So I think there is an issue on the internet connection side. Please reach as soon as possible.
Thanks.
Kind regards
Edit: Moved from DSL to Kabel
am 28.07.2018 20:17
Hi ig-voduser,
I will prove the connection and then we'll speak about what to do next. Please send me your name, address and customer number by PN. Please also let me know here if you have sent the message.
Kind regards
am 29.07.2018 02:13
Hi Marco,
Thanks for your message. I send PN now.
Kind regards
am 30.07.2018 14:54
Hi Marco,
Did you get my message?
am 31.07.2018 11:41
Hi ig-voduser,
a technician will fix your connection today between 14:00 and 17:00 o'clock. Please tell me, if everything worked out than.
Kind regards
am 31.07.2018 12:02
Hi Marco,
Still, I don't know where they will come. I tried to get an answer about the address (which I wrote details here: https://forum.vodafone.de/t5/Feedback/Support-service-hung-up-on-me/m-p/1714632#M27212) but I didn't get an answer. They need to come to my current address which I sent to you (also it's on Vodafone system) somehow some of the technical support see my old address which I have no idea why they see that.
am 01.08.2018 18:47
Hi @ig-voduser,
well, the colleagues fixed the adress. I also saw a technician was there on your new adress, does the internet works now?
Regards
