Internet connection speed drops
gaaarfild
Digitalisierer
Digitalisierer
Hello,
My contract number is ***.
I have a connection issues that appear randomly and very often. Impossible to work.
Speed periodically drops to 0 for a couple of seconds and then returns back.
I use wifi connection.
When I tried Cable connection on other device, it was working while on wifi device not. At the same time.
Best regards,
Dinar.
Edit: Customer number removed for privacy reasons. VF_Grit
Wallace
Hi Dinar,
the line currently looks excellent. Can you please give the 2.4 and 5GHz WiFi a separate SSID and then test it again?
Regards
Wallace
