Hilfsangebote außerhalb der Community
  • Jetzt mit Tobi chatten Chat Jetzt mit TOBi chatten
  • Nutze unsere Hile bei Störung. Störung? Nutz unsere Hilfe bei Störung!
  • Entedecke unsere digitalen Lösungen und nutze sie Mehr? Entdecke unsere digitalen Lösungen und nutz sie!
High packet losses
RadoKara
I have problem with packet losses - ie during ping of google.de I get 14 percent packets lost (connection over cable, not WiFi). I already was trying VodafoneStation reset, I checked all cables (ethernet and coaxial), but nothing is helping. Is there anything, what can I do? Please see attached ping statistics.
6 Antworten 6
RadoKara
Any ideas? I try again to reset router but it didn't helped.
Tina
Hallo RadoKara,
can you please perform a tracert?
For a closer look send me the following informations in a private message:
full name
date of birth
address
customer number
Write a short reply here afterwards.
Best regards
Tina
RadoKara
Hello,
In attachement you will find traceroute as requested.
Regards
Radoslaw
ERFD
Hello RadoKara,
nothing conspicuous is visible on the modem. Does the problem occur around the clock or only at certain times. Does this affect the bandwidth?
Best regards Fred
RadoKara
Hello Fred,
It seems to be random - sometimes I have stability errors during day, sometimes it is on evenings, I do not see a pattern here.
I checked all connections again and I was trying to use difderent TV socket - still the same.
Maybe the router itself is not stable?
Is this possible to get other device? I don't need WiFi or other fancy features, it can be the simplest bridge (coax-ethernet).
Regards
Radoslaw
Hello RadoKara,
the signal values at the modem are currently ok. Gladly we can try to exchange the modem.
Best regards Fred
