Connection speed is extremely low (below 5Mbps)
edxmas
I'm sorry, but I only speek english. I tried to contact the customer service, but they could assist in german only.
I've a 200Mbps contract, but download speed is pretty bad, I can't watch TV, video calls, and navigation usually times out. The test is reporting a speed below 5Mbps, and it doesn't even complete because it times out (please, have a look at the attachment). This is happening since a while already, but I couldn't expect such a decrese in the quality of the service.
Can you please assist and fix the problem as soon as possible?
Thanks a lot for your help.
8 Antworten 8
reneromann
Could you please post screenshots of the modem status information page?
There should be a long list of frequencies, signal strength indicators, modulation and MSE/SNR values...
Please, find it attached.
Hello edxmas,
is the speed low all the time or rather at certain times, like evenings or the afternoon? Did you test through LAN or wireless? Please also send me a private message that includes your date of birth, the customer number and the address. Answer again in this thread after you sent the message.
Kind regards,
@edxmas Your signal is weak - I think a technician has to come and fix it.
@Claudia Die Signalwerte sehen alles andere als gut aus. Im Download fehlen 2 Kanäle komplett (wsl. 626 und 642 MHz), ein weiterer ist komplett gestört (682 MHz mit 25 dB SNR), generell sind die DS-Kanäle im unteren Frequenzbereich etwas zu gering (138..146 MHz mit 29..31 dB SNR). Und im Upstream reicht die Verstärkung im RK nicht nicht aus, dadurch fallen 3 der 4 Rückkanäle weg. Da muss ein Techniker den Anschluß neu einpegeln...
@Claudia I sent you a private message. Yes, I use a cable to check it.
Yesterday evening the connection was even dropping intermittently, it wasn't possible to navigate at all. Today it's slightly better, I could make a speed test at least (Ticket E6RB4 - 25Mbps dw, 12 ms latency). Still, it's not an acceptable quality.
@reneromann I'm looking forward to have it solved. Is it possible this week?
Thanks for your support!
Moni_GK
Hello edxmas,
on your line there are two things that don't quite fit.
On the one hand there is a too high load and this leads also to the fact that the speed is so low.
But also some line values don't fit properly. Here I would like to send you a technician. He will not perform miracles, but it will certainly be a little better.
For this I still need a phone number from you, so that the colleague can make an appointment with you.
Will the technician come to the house with your help?
Best regards
Moni
edxmas
Can you please elaborate: What do you mean by "high load"?
Well, I expect Vodafone will respect the minimum guaranteed by the contract.
I will send my phone number in private. Thanks
ERFD
Hello edxmas,
there is too high a load factor (too many users) in the core hours and therefore the contractually guaranteed volume cannot be achieved during this time.
Best regards Fred
