am
01.08.2019
15:03
- zuletzt bearbeitet am
01.08.2019
15:16
von
Tina
Broadband- WIfi vefry Slow, doesn't connect in other room and disconnects very frequently. Doesn't get regular streaming to TV and Keeps loading for Youtube/Netflix videos. I am facing this problem since I took the connection. Please send someone to check it or guide me how to proceed as soon as possible.
Karan Singh
0152***
Edit: I made your number unrecognizable.
am 02.08.2019 10:00
Hi KaranSingh,
do you have general problems with your connection or WIFI only?
Which modem do you use?
Regards,
Jens
am 07.08.2019 14:07
I have a problem with both Wifi connection and Internet speed.
I am using the modem which I peoided by you for free with the connection.
As the router, you've gotten heated up all the time and I feel it's not good. Plesae advice me if need to change the device as well because some friends of mine were suggesting to replace it, they had the same issue with Vodafone.
@Jens-K wrote:Hi Karan Singh,
do you have any problems with your connection or WIFI only?
Regards,
Jens
Regards,
Karan Singh
am 08.08.2019 10:55
Hi KaranSingh,
we have several modems for DSL and cable.
Please have a look which model you use.
If the connection is too slow via LAN and WIFI, I'm pretty sure there is no problem with the modem.
Please do at least 3 Speedchecks here: http://www.speedcheck.vodafone.de and post the results (without ticketnumbers) here.
Please use LAN and do not download or stream anything during the tests.
Also do not use VPN or any extension cables or (powerline-) adapters.
Regards,
Jens
am
10.08.2019
18:14
12.08.2019
14:29
von
Seb4sti4n
Hi Jens,
As per your drection, I have done the speet test three times, result is attached and its really a very poor speed and most of the times its even worst then this. However, the bigger issue is disconnect of connection all the time, I am not able to do anything continuously.
Also, I am using the default modem which was sent by Vodafone when I applied for the connection, grey in color.
kindly, send someone to look at the issue himself and fix it at the earliest.
Regards,
Karan Singh
XXX
Edit: @KaranSingh Remove personal Data. VG Sebastian
am 12.08.2019 14:35
Hello @KaranSingh,
would you please send me a private message with your customer number, your cellphone number and the numbers of the tickets from the speedchecks.
I will take a look at this and check it for you.
Best Regards
Sebastian
am 14.08.2019 15:39
Hello, KaranSingh,
does the WLAN fail on all devices in the household? Does this happen at the same time? Are both radio frequencies affected? Are there many foreign radio networks in your area?
Best regards Fred
am 19.08.2019 15:47
Yes, the WLAN fail on all devices in the household and Yes it happen at the same time,
I am not sure about the radio frequencies and foreign radio networks in my area.
Well, Its been lot of question-answer on the posts for quite a long time. It would be rather better to send a technician and find out the real issue.
I am paying for the service for about 4-5 months but not able to use it with peace of mind, I hope you understand my problem and resolve it at the earliest.
am 21.08.2019 11:14
Can someone respond to the issue at the earliest or guide me to expedite the process.
am 21.08.2019 15:36
Hi Karan,
I can see the disconnects. Thgis happens very often. The signals seems to be okay and other connections at your place don't show the same issues. Inj first step I'd like to replace your modem for free. Is that okay for you?
Kind regards
