TV international englisch
20454
Two months ago I ordered Vodafone TV International Englisch Cable. I am unable to install it. I have asked in the shops for help. No help. Can you pls. tell me how to install it. And get it working. Also, which channels are included in the package. Thanx.
Stephan
Hi 20454,
thanks for your reply.
Since the exchange of the defective receiver was the solution to the puzzle and now everything works as it should, I close the thread here as well.
Finally you get a small credit from me for the trouble you had.
I wish you a pleasant week.
Regards
Stephan
21 Antworten 21
Thomas
Hi 20454,
there's nothing to install. The activation of the channels is done via the smartcard or directly on the Giga TV Box. You can find an overview of the included channels here.
Thomas
20454
According to your information TV International Englisch Cable should contain BBC Entertainment + some other film channels. I have now once again activated smart card XXXX without receiving any channels. WHY??? Do I need a new smart card??? I ordered this service two months ago. If it is impossible to receive these channels will you therefore cancel it as I do not want to pay for a commodity I am not getting.
Edit: Moved you new Thread to your existing Thread. Again: Don't open new Threads for the same Topic. Thanks.
Also removed the Smart Card Number.
Hello 20454,
what error message do you get?
Please send me a PM with your customer data (name, address, customer number, date of birth and the smartcard number).
Then contact me here again when you have sent the data.
Best regards
Moni
Hello, 20454,
do you use our smartcard and our receiver?
Best regards
Moni
20454
Vodafone Digital HD-Reccorder Sagemcom
Smartcard Vodafone
20454
Do you have any news???
Thomas
Hi 20454,
everything is booked correctly so far. Do you get an error message at the channels?
Regards
Thomas
20454
Hinweis
Chipset pairing required
Will you therefore pls. cancel this nonexisting "service:
Thomas
Hi 20454,
we sent a new signal to the card. Please switch to one of the non-functioning channels and leave it switched on like this. The activation should take place within half an hour.
Regards
Thomas
