Change to a lower internet tariff
MMoataz
Hello, I am currently having a Red Internet & Phone Cable 1000 and would like to change to Red Internet & Phone Cable 250 instead (39,99€/month). On the website I only found options to change to higher tariff not lower ones.
I believe changing tariffs happens smoothly without the need to cut the service. Is that correct?
4 Antworten 4
Thomas
Hi MMoataz,
let's take a look. Send me your customer number, name, date of birth and address in a private message.
Then reply again here in the post.
Regards
Thomas
Hi MMoataz,
thanks for your PM.
The 250 rate is not included in your switch guarantee. You can, for example, switch to the Red Internet & Phone 200 Cable at 39.99 euros or to the Red Internet & Phone 400 Cable at 44.99 euros. Which one should we switch to for you?
Best regards
Lars
MMoataz
Thank you Lars
So please change my speed to Red Internet & Phone 200
Thomas
Hi MMoataz,
the change is ordered and you will receive a confirmation.
Regards
Thomas
