Sagecom 5460 very slow web configuration UI and Why there is no Ipv4 WAN IP>
ntwobike
My router web configuration page is very slow, multiple times it hangs, really annoying. Is there a solution for that? Also as i see my WAN has only an ipv6 address why there is no ipv4 address? how do I get an IPV4 wan address for the my router?
Hello ntwobike,
there is no known problem with the web interface of this router. Did you check if it is better after a factory reset? The standard is DSLite, you can get an IPv4 address if you enable the bridge mode. This setting can be found in the customer portal under "Interneteinstellungen".
Kind regards,
