am 30.10.2018 13:41
Hello!
I have a Wifi router Compal CH7466CE provided with Vodafone contract. For the last 1.5 months I am experiencing WiFi service degradation withing my apartments. For some reason network's range became too short, I can use wifi normally only within 3-4 meters from the device. I did not change the default settings on the device and already tried "Reset to default" solution and it didn't help. I couldn't find any transmission signal strength settings so I have no idea why the range is so short now. The previous year it worked fine though. Device reboots didn't help as well.
Can I request the device replacement?
Thank you!
am 09.11.2018 06:43
Upstream signal values are normal.
What about the downstream? Can you post that values?
am 14.11.2018 12:08
Hello wave911,
okay, then please send me your address and customer number in a private message. Answer here again afterwards.
Kind regards
am 14.11.2018 21:23
Downstream pic #1 please find attached.
am 14.11.2018 21:24
Downstream pic #2 please find attached.
am 15.11.2018 17:04
Downstream is ok. Upstream Modulation of channel 4 should be 64qam not 32qam. Signal strength is a little bit to high.
In my opinion a technichian has to check your connection.
