am 07.06.2020 14:13
Hallo, mein Deutsch ist nicht sehr gut, dann möchte ich auf Englisch schreiben. Sorry.
I have a DSL-Kabel 50 service with CH7466CE Wireless Voice Gateway modem - Firmware version 4.50.20.3.
My modem does not work when I use both Band Modes (2.4 GHz and 5 GHz), Therefore, WiFi goes completely down every ca. 10 minutes. so it doesn't work. but when I turn off Band Mode 2.4 GHz, everything goes well again.
I even get the Trace Route from Google.com, Local path and gateway. I can see clearly where the problem is. I phoned the vodafone several times on this subject, and even opened a ticket. but unfortunately nobody understands me. Actually this is very simple, the modem has to be changed, but unfortunately they do not do this.
I would like help from vodafone and other friends. please help me if possible.
Thank you very much indeed.
Best regards,
Jaschar
am 10.06.2020 10:02
Hello, Yashar,
you tried a factory reset and see if it works better when the wireless networks are disconnected. Have you tried separate SSIDs and changed the channels in 2.4 GHz?
Best regards Fred
am 15.06.2020 21:18
Hi Fred,
I did the best, I reset the factory settings many times, and even separated SSID (2.4 GHz and 5 GHz) networks. But unfortunately it is not working properly. :((
By the way, why is Vodafone Support not responding? i don't understand her at all. :0
Best regards,
Yashar
am 15.06.2020 21:22
Fred, I need to change my Modem, how can i do this? have you got an idea or solution? ![]()
Regards,
Yashar
am 17.06.2020 09:47
Hello Yashar,
are then both networks affected? I can see what I can do. Please send me a PN with your customer data (name, address, customer number and date of birth).
Please contact me here again when you have sent me the data.
Kind regards
Moni
am
10.07.2020
17:18
- zuletzt bearbeitet am
10.07.2020
18:40
von
Anett
Hi Moni,
At first I would like to thank you for your answer. please accept my apology, that I answered you very late.
Yes, unfortunately both networks are affected.
You can find the information you want below.
Address : ***
Customer Number : ***
Date of Birth : 2***
Thank you again,
Best regards,
Yashar Amirabedin
Edit: personal data removed. Please do not post them publicly.
am 13.07.2020 09:06
Hello, Yashar,
please do not post any data publicly. Please send me the data by PM.
Best regards
Moni
am 14.07.2020 13:41
Hello, Yashar,
would a trade-in for the router be okay with you?
Best regards
Moni
am 14.07.2020 16:57
Hello Moni,
So you want to take back my Modem and give it a new Modem?
Did I get right?
Best regards,
Yashar
am 15.07.2020 10:39
Hello Yashar,
not quite. I'll send the device out, and when it gets here, you send the old one back.
Greetings
Moni
