- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
am 22.12.2018 21:46
Hi everyone,
I just have a Gigabit Internet connection with a Wlan Kabeldeutschland modem.
I just isntalled my own dns server in home and use my own advanced hardware firewall.
The only problem which remains is vodafone router built in firewall!
When I turned it off it will remains off only for 24 hours and will turn on automatically!
So How can I turn it off permanently?
also here is my Firmware version: 01.01.117.01.EURO
Thanks a lot and have a lovley day.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 21.11.2019 12:10
I have already tried a hardware reset before.
Did you do anything now specifically ?
Unless you did something now specifically, I don't see the point of doing the hardware reset again, since it will not change anything, aside from dropping all my DHCP leases and wifi customization.
Please let me know
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 21.11.2019 13:13
Hello alexnastas1,
I'm sorry, I didn't know you already did that.
Do you want to try a router swap?
Best regards
Moni
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 21.11.2019 15:35
Moni,
I don't think there is anything wrong with my router. I think this is just the way it's designed. It is designed to re-enable the Firewall after 24h hours. I get a message about this. So how would a router swap solve my problem ?
I was asking if by any chance there is trick to disable the firewall permanently. Maybe there is a specific firmware that I could install ?
- « Vorherige
- 1
- 2
- Nächste »
