am 07.05.2019 18:11
Hi, I have changed recently from different provider to CallYa Flex. I get the SIM card, and downloaded the App CallYa Flex and it worked for some days.
Some day ago the App CallYa Flex stop working (it says there is no CallYa Flex SIM card installed) and a Vodafone notification requested to install App Mein Vodafone.
Now the App Mein Vodafone indicates that I have the Plan (Tarif) CallYa Smartphone Special, which is more expensive than the CallYa Flex.
Why did Vodafone change unrequestedly my Plan (Tarif)? I wish to stay with CallYa Flex.
Addtionally I have got the 25EUR bonus for changing to vodafone from different provider yet.
Thank you
am 13.05.2019 15:57
The Problem as solved, and also I got the missing bouns. Quick and nice job by the Vodafone Team
07.05.2019 18:40 - bearbeitet 07.05.2019 18:41
Hi @Walrus,
That sounds strange. Normally the tariff won't be changed without request. And changing from CallYa flex to smartphone special is only possible by phone call.
am 07.05.2019 23:13
I correct myself:
Addtionally I have NOT got the 25EUR bonus for changing to vodafone from different provider yet
am 07.05.2019 23:14
Yes, I have not call them in any case. I just happend suddenly. I expect the moderator can help to correct it.
am 08.05.2019 09:50
HI Walrus,
send me the affected number by PM (left click on my name and then right on "Send this user a private message"), then I can check your concerns.
Best regards
Doreen-123
am 09.05.2019 14:08
Thank you Doreen-123 for yout quick answer
I sent you my nummer.
Best
Walrus
am 13.05.2019 15:57
