Vodafone Kabel detuschland Internet keeps disconnecting
dinesh321
Hello,
I have a Vodafone Kabel connection! My internet keeps disconnecting and it's very annoying! Please test and fix it as soon as possible. I can send you customer details privately
My contract was new, the Initial 6 months I opted for high speed(500 Mbps) where I don't have any internet issues. After 6 months I changed to 100 Mbps and then the problem starts - which is the internet keeps disconnecting regularly
Hello dinesh321,
i have looked at it and there is already an order for this to be fixed. I have set a ticket for you and you will be informed about the completion of the work through that.
Best regards
Nancy
9 Antworten 9
Tina
Hello and welcome in our community, dinesh321.
So that I can make an initial assessment, please answer the following questions:
  • Which modem/router do you use? (e.g. Hitron)
  • Do you use a rental device from us or do you have your own device?
  • Which error occurs? (Speed too low; Packetloss) Send also screenshots of speed tests (with date and time) and tracerts/ ping plotter measurements in case of packetloss or ping problems.
  • How is your end device connected to the modem? (LAN; WLAN; additional router; PowerLAN)
  • Which browser do you normally use? (e.g. Firefox)
  • Which operating system do you have on your computer? (e.g. Windows)
  • Beginning and period of the disturbance (e.g. since beginning of April; only in the evening)
  • Upload a screenshot of the signal values. You can find them in the user interface of your cable router via 192.168.0.1 or via 192.168.178.1 for the Fritzbox.
Thank you and best regards
Tina
Hi Tina,
Please find the answers below! Please try to fix it asap
    • It was from Vodafone, device id is Vodafone 6c4c
    • I rented it from you
    • please find the screenshots attached. I took from ping plotter
    • WLAN
    • chrome
    • Windows, Mac OS
    • Since August 2021
Tina
Hello dinesh321,
for a closer look send me the following informations in a private message:
full name
date of birth
address
customer number
Write a short reply here afterwards.
Best regards
Tina
Hello dinesh321,
Best regards
Nancy
Hi Nancy,
I have been waiting for 5 weeks for the ticket to be fixed! I see no response and no action to date!
Can you fix it immediately or increase the speed of the internet(maybe it will solve the issue as i explained before) with the same price or give the voucher for the last two months or cancel the contract
Please reach on it asap! I am working from home and I cant afford to wait for days, weeks, and months without seeing anything
Thanks
Dinesh
Hey @dinesh321,
we cant fix it earlier, im sorry for that 😞 I can offer you a discount for 50% of your monthly payments if you want.
Regards
Hi Tobias,
Thanks for considering my request. Please provide the discount and try to fix it as early as possible!
Just saying if possible it will be great if you can increase the speed instead of discount
Thanks
Dinesh
Hi Tobia,
Please confirm the discount! also if you have any update please let me know the progress on the ticket
Thanks
Thomas
Hi dinesh321,
sorry, unfortunately nothing new about the ticket yet. We have deposited the credit note until the end of December. You will see it with the next invoice.
Regards
Thomas
