VF wifi station 6 Internet light red blinking
Clive1
Cable, Hi to whom it may concern.
We dont have internet access since 5 or 6 am, the VF wifi station 6 shows on and off red light from the Internet light, its usually white and doesnt blinks. I tried checking the router access and resetting the device but still no Internet. Thnx if anyone can help me solve the problem
R4mona
Good morning @Clive1,
What is your current situation? Can you use your connection again without any problems? If not, please use our fault finder to check your issue. This will show you all the information about known disruptions in your region and keep you up to date with all updates. ❤️ If you don't find what you're looking for there, it will redirect you accordingly.
Kind regards
R4mona
