am
04.11.2021
13:47
- zuletzt bearbeitet am
04.11.2021
17:59
von
Hello! I'm a brand new vodafone customer and I need some help.
Just got to a new flat and plugged in my router. Everything looks great, but the Internet keeps disappearing every 30 seconds or so. IT looks fine on the router but whenever I try to connect it just disappeares.
I did all the troubleshooting, plugged and unplugged it, went through the online helper and all of that, turned it off and on about 20 times now. Any ideas, anyone?
Thanks a lot!
Tori
Edit: @ToriMori Moved in the right board. Best regards Kurtler
am 06.11.2021 12:29
"...but the Internet keeps disappearing every 30 seconds or so"
What does disappear, LAN/WLAN?
Please post the VF Station Eventlog and docsis values
am 08.11.2021 08:51
Everything was disappearing. It was just losing everything and looking for connection again.
But it's fine, turns out I was sent a router that's broken. I tried one borrowed from a friend and it's working fine. Anybody knows how I can send the one that's faulty back?
Thanks a lot.
08.11.2021 09:55 - bearbeitet 08.11.2021 10:00
What type of contract do you have? e.g. 500/50
Type of the original router?
Type of replacement router?
Screenshot Docsis signal values?
State of residence?
Screenshot speedtest?
It may well be - assuming good signal values - that the docsis 3.1 channel is OFDMA poor despite all this. A docsis 3.0 router does not have this channel, but will be limited in speed to max. 600Mbits?
This concerns contracts from 500MBits upwards.
In case of a replacement you will get a docsis 3.1 router again.
But without data, you don't know anything.
Some data is needed to help,
am 08.11.2021 14:58
Hi ToriMori,
let´s take a look. Send me your customer number, name, date of birth and address in a private message.
Then reply again here in the post.
Regards
Thomas
am 11.11.2021 11:08
Hi Thomas,
sent the PM
Thanks,
Tori
am 16.11.2021 19:46
Hi @ToriMori,
the line looks fine actually, their is nothing wrong actually. Where do you got these disconeccts? Wifi, Lan? Does it accure also actually?
Regards
