am 04.08.2021 09:25 - zuletzt bearbeitet am 05.08.2021 12:04 von DanyG
Works fine from mobile network but not on DSL / WIFI from Vodafone Kable. Please help.
Edit @Lalit91 Moved to Cable. BR, DanyG
am 05.08.2021 11:05
Kindly support this has never happened before I cannot attend any meetings Webex is blocked. WHY???
No one is responding from customer care.
am 05.08.2021 12:17
Hi Lalit91,
have you ever contacted Webex support?
Regards
Stephan
am 06.08.2021 11:40
Hello @Stephan ,
Thank you for your reply!
yes internally no one is facing this problem. I am working from home and everyhiting was working fine no issues for last 8/9 months. When I connect on mobile data everything works fine, it does not work via WIFI/DSL.
You can contact me on my number for speedy closure please.
Regards,
Lalit
am 06.08.2021 12:13
Hello Lalit91,
are there any restrictions with other services through our line and only with My Webex? If it is only this service, please consult with the responsible department. We can not check your software for errors.
Best regards Fred
am 06.08.2021 13:41
Thank your for your response.
This is not a software error. Software works perfectly fine without Vodafone wifi. on O2 wifi it works flawless. Its only on Vodafone it does not work. I am myself a software engineer so i very well know whom to contact with what issue. Kindly provide a service person whom I can prove it is something related to vodafone network and not related to any software.
JFYI:
I am not on any VPN or internal nework I am in home network.
Regards,
Lalit
am 06.08.2021 13:51
https://forum.vodafone.de/t5/St%C3%B6rungsmeldungen-Internet-TV/WebEx-Zugriff-blockiert/td-p/2667076
I see similar complaints here but no solution.
Request your earliest support.
am 09.08.2021 09:44
hello Team,
My Webex has started working again today. Didnt contact anyone else other than you guyz.
Thread can be closed.
Regards,
lalit
am 09.08.2021 14:43
