31.05.2024 18:55 - bearbeitet 31.05.2024 18:57
Hello
I made a Kabel contract on the 26th of May and in the confirmation it said that I should receive the activation code in the next days but after five days still didn't receive it although I received something called service pin. What should I do to activate it
My second question is that I have my own router fritzbox 6690 that my friend gave me . When I connect it to the cable socket and connect it to my phone it redirects me to the activation portal so it seems like new. Will it work with no problem in the activation date which is 4th of june
am 31.05.2024 19:34
without the activation code you can' activate your 6690
hopefully article number on the back is correct
needs to be 20002965
am 31.05.2024 19:57
The article number is 20002993 is it ok
am 31.05.2024 20:00
At the activation portal it needs the kundennummer and Aktivierungscode
am 31.05.2024 20:05
@Azz455 schrieb:The article number is 20002993 is it ok
No, it isn't
this is a rental device and can't be activated
give it back to your friend and if he don't need it he should send it back to Vodafone
am 31.05.2024 20:14
Can I apply to rent a device from vodafone after I made the contract because I don't want to cancel it and start all over again
am 31.05.2024 20:22
should be possible
add the Homebox option to your contract
am 31.05.2024 20:26
Could you please explain the process to
Sorry for taking your time
