- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
am 08.01.2025 18:07
We have a Frtiz!Box 6660 and have been having connection issues for what seems like months now. The last month has been extremely bad and I started using PingPlotter again to check the connection. Every website or IP address I try has significant packet loss. It does not matter which device I use or if the connection is wireless or wired. I am constantly disconnected from the wifi throughout the day and it is the the point where it is almost unusable. What is happening here?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 08.01.2025 19:18
du hast schon PL in deinem Netzwerk, suche erst mal diesen , alles abstecken , Wlan aus machen , dann nach und nach wieder alles in Betrieb nehmen und gucken welches Gerät den Loss macht!
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 09.01.2025 13:20
I unplugged everything and then connected a single device and still had packet loss. I tried 3 devices in total and all were showing packet loss. I even tried the other coaxial plug in the bedroom, but still nothing improved.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
09.01.2025 13:34 - bearbeitet 09.01.2025 13:37
@harrijc3 schrieb:I unplugged everything and then connected a single device and still had packet loss.
did you also try a new network cable to connect your device to the Fritzbox?
and are you connected directly with the Fritzbox?
paket loss starts in your network
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 14.01.2025 17:25
I tried 3 different network cables directly to the fritzbox and also tried 2 separate devices with the wifi disabled, but still no improvement. Sometimes I show no packet loss at the router, but there is always packet loss on multiple hops. Today I was disconnected around 5-6 times per hour. The service is nearly unusable in this way.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
am 14.01.2025 17:32
then try to contact support and let them exchange the Fritzbox
