am 15.05.2023 11:10
Using the Vodafone InfoDok - 251, I applied for a CallYa card take over and I received a message on the 04-May-2023 that my card will be switched on the night of May 5th, 2023 and I should register myself using the registration link . Already on the 5th May, I could see my personal details correctly displayed in my vodafone App.
But, my SIM card is still inactive although it has now been 10 calendar days since I uploaded my verification documents in the above mentioned link. Could someone from the vodafone team help me check the status of my request?
Many thanks!
15.05.2023 11:22 - bearbeitet 15.05.2023 11:23
Hi @Siva89,
I recoomend in that case that you get in contact with VF directly (not the hotline bei call!).
Use one of the both social media channels (Facebook or Twitter) --> contact channels <--
I'm sure that your SIM-card will be activated in a short time.
Keep us updated. ![]()
Hi @Siva89,
am 15.05.2023 11:42
Thank you for your recommendation @Mav1976
It seems most of the communication channels are moderated by TOBi. After couple of unsuccessful attempts at trying to understand my problem, TOBi says it'll schedule a callback from a support person without realizing that I cannot receive incoming calls! I tried to ask, if it can schedule a callback using WhatsApp, but TOBi didn't understand that either and just asked me to answer Yes or No for a call back! 😄
am 15.05.2023 12:49
Thanks again for the list of different contact channels @Mav1976!
I contacted them via Twitter DMs (TOBi was not involved there) and they resolved it very fast.
am 15.05.2023 16:29
