Hilfsangebote außerhalb der Community
  • Jetzt mit Tobi chatten Chat Jetzt mit TOBi chatten
  • Nutze unsere Hile bei Störung. Störung? Nutz unsere Hilfe bei Störung!
  • Entedecke unsere digitalen Lösungen und nutze sie Mehr? Entdecke unsere digitalen Lösungen und nutz sie!
Need Return slip
Akash123
My contract started on 2019-7-17. I moved to new location and there i didnt have vodofone cable connection. So I have cancelled vodafone contract on 2020-12-08. As per the contract, I have to pay to the internet bill till 2021-03-08. Now I want to return my router to vodafone. When i received the vodafone router, it came along with one return slip. Shall i use the slip to return my vodafone router? If yes so, the reurn slip has my old address. Will i get new return slip with the updated new address.
Regards,
Ak
Edit @Akash123: Moved to contract board. Regards Jens
You can use the old return slip. It doesn't matter that the old address is on it.
Best regards Kurt
Best regards Kurt
Thanks for the reply. I have few questions
  1.  I have got the return slip 1.5 years back. Shall i use the return slip still? Because There are lot of threads about the validity about the reurn slip? In some threads, It is mentioned that return slip validity is only 60 days after receiving the router. In some threads, it is mentioned that user can use rerturn slips without any time limits but he has to bear the costs. Which is correct?
  2. In case if I send the router with return slip(with old address) and if vodafone resends the router back to me due to any issues, to which address they will send  it to me? Is it to my new address or Old address)
Regards,
Ak
1. The return slip is still valid. I only recently sent something back. My return slip was 2 years old
2. If for any reason the router is returned to you by Vodafone, it will be sent to your new address.
Best regards Kurt
