am 02.09.2024 13:06
Sorry for posting in English since I cannot speak German but you can reply back in German if you understand my question and you can help. I bought a used Fritz modem from a vodafone user (she confirmed that it was her own modem) and started using it instead of my rental vodafone modem that I got with my subscription 3 years ago. Now, can I return this vodafone modem back to Vodafone since they are probably charging monthly rental cost. If yes, how can I return and stop paying modem rental cost?
am 02.09.2024 14:06
am 02.09.2024 13:31
Welche Fritzbox hast du denn gekauft? Wie lautet die Artikelnummer? In welchem Bundesland lebst du?
am 02.09.2024 13:40
FritzBox 6660 Cable, item #: 20002932, Frankfurt Hessen
am 02.09.2024 13:47
Die Box bekommst du nicht freischaltet, da es kein freies Endgerät ist, sondern ein ehemaliges Leihgerät! Freie Boxen (Fritzbox 6660) haben die 20002910! Hier etwas Lesestoff dazu. Gib die Box zurück und hole dir eine ausm Fachhandel.
am 02.09.2024 14:01
But I connected it and it works in my home? She also said it belongs to them not Vodafone (unless she did not know). If she sold a device that belongs to Vodafone, can I still use it or I should not use it?
am 02.09.2024 14:06
am 02.09.2024 14:07
Your box is a rental box. This cannot be activated. The reason why this works for you is that it is still activated on the previous owner's contract.
Best regards Kurt
am 02.09.2024 14:10
Thank you for the valuable inputs so I will put my previous vodafone modem back. I also purchased two fritz repeaters, can I use them with my Vodafone modem, I guess this should not be a problem.
am 02.09.2024 14:13
better you would buy a Fritzbox with the following articel numbers
am 02.09.2024 15:40
The thread has been marked as resolved. Then I'll close the thread here.
Best regards Kurt
