09.02.2022 22:04 - bearbeitet 09.02.2022 22:04
Good afternoon
anybody using PPoE passthrough on FritzBox! to get NAT1 connection on a PS4 ?
Actually I'm on NAT2 and it is not bad, but I was wondering if it is possible.
I don't know if Vodafone adsl support it and where to get Zugangsdaten
Thanks
am 10.02.2022 00:32
are you using a DSL modem?
which one?
am 14.02.2022 20:53
Fritz 7590.
On the Fritz I can enable the passthrough but I don't have PPPoE access credentials to setup on the PS4 and I don't know if Vodafone allows for two connections
am 14.02.2022 21:10
which benefit do you expect?
am 19.02.2022 23:43
Management of priorities on Fritz is a bit too basic and basically it is only in the transmission direction
It is very easy to see ping changes with moderate load on other devices, far away from saturating the line
I would like to see if there is a benefit.
