am 26.08.2022 13:23
I have bought a gigaNetz internet for my home internet. Even after activating with the activation code in the website I couldn't access the Internet. The Internet (red light) just blinks in the device. I tried restarting it multiple times but it just ideals at blinked red light in Internet.
26.08.2022 14:14 - bearbeitet 26.08.2022 14:15
I asume you are talking about a Gigacube LTE router
you have to login to the Gigagcube webinterface (login password is printed on the device) and fill in your credentials (SIM pin, etc.)
am 29.08.2022 11:18
Hi Robert, thanks for your reply!
I did login to the web interface, but I cannot find anything of that sort.
FYI I'm using this router, which is GigaCable I think
am 29.08.2022 12:16
this is indeed Cable NOT LTE
if internet light blinks red there is a problem with the cable connection in your flat
am 08.03.2024 10:36
Hello Even I am facing the same issue , any idea how was it resolved later for you @RahulNarasimman
