[English] PS5 NAT Type change
Maxi111
Hello,
I am struggling with changing NAT Type on my PS5 as it's impossible to play online with current one (NAT type 3). I added IP to DMZ, I made port forwarding, I changed Wi-Fi to cable and nothing helps.
I believe PPPOE might help, but I have no idea what my credentials are.
SebiQuedi
Hi @Maxi111 If you're using a PPPoE internet connection, you'll need both a username and password to connect your router to the internet. These credentials are provided by your Internet Service Provider (ISP) when you set up your connection. All information concerning your Vodafone account can be found here: MeinVodafone
