am 24.08.2024 22:47
My Vodafone Station is the following:
am 25.08.2024 13:51
activate DHCP Option 60 on your Asus Router
am 25.08.2024 04:59
So, some update after some experimentation - the Bridge Mode works BUT ONLY when I have my PC directly connected... does not work when I have my ASUS router connected instead 😞
For the PC it gives an IP of range 78.42.249.x/255.255.254.0 and works without issue.
For the router it gives completely different IP: 176.198.247.x and no internet.
How to resolve that?
am 25.08.2024 12:41
Hello @ethernall,
you can manage the Bridge Mode in our customer center.vod.af/App1
You can reach our service via these Contact channels .
BR J0hann
am 25.08.2024 13:16
Then something is off with the configuration of your Asus router.
Tried to reset the Asus? - Which one?
am 25.08.2024 13:27
Often you need to restart Vodafone-Station and Router after you changed Vodafone-Station in Bridgemode
am 25.08.2024 13:51
am 25.08.2024 15:37
Hello again and thanks a lot for the fast response! Problem is solved! It was indeed the DHCP Option 60 [facepalm]. I entered smth there and set IAID/DUID checkbox (just in case) and voila - after enabling bridge mode again, and waiting a little bit (first thought it is the same story as it gave me same WAN IP) this time it works 🙂 I hope it is stable. Thanks once again!
am 25.08.2024 15:41
Hi @ethernall,
thanks for your feedback!
I'm happy everything works now and that our community was able to help! 😊
Therefore pls mark the solution, so I can close this thread.
Kind regards
Chr1ssy
am 25.08.2024 15:50
Done! Sorry - I did not know how it works here. Thanks to everyone for the fast help once again!
am 25.08.2024 16:07
No problem! 😊
You're more then welcome.
If there is anything else in the future, you can of course open another thread, or contact us directly.
Have a nice sunday. 🌞
Best regards
Chr1ssy
