Best Access Point for Ethernet outlet
d3d3
What's the access point do you recommend that I can plug into wall Ethernet outlets inside the rooms for both wired and wireless access? This is mainly to increase the wireless coverage but having wired is nice side benefit in case I want to use it.
Any recommendation? People talk highly of TP-Link and Ubiquiti but not sure which brand/model I should go with without spending 3 digits.
Not sure if it needs to be compatible with the main router but I am using one of the gray colored Vodafone brand routers that comes with Giga Cable tariff.
Menne99
Ubiquiti is my favorite, look at Power on Lan feature! u need no Powercable..
Der glubb is a Depp
d3d3
Any specific model you have used that you are happy with?  I am gonna look at power on LAN if it saves me from cables...
Menne99
