*** marked as completed but nothing changed?
mangatmodi
I raised a fault service request(***)  where my internet connection gets completely dead. Only troubleshoot is too restart the router. After every 15-30 mins I have to restart the router.
Note that:-
1. I have directly connected with cable too, it is still dead so not a wi-fi fault.
2. The problem is quite old. It required 1-2 restart in whole day, but now I need to restart after every 15 mins.
3. The ticket was marked completed, but the situation is same.
   **  Google Translate **
Ich habe eine Fehler-Service-Anfrage (***) ausgelöst, bei der meine Internetverbindung komplett zerstört wird. Die einzige Problembehebung ist, den Router neu zu starten. Nach jeweils 15-30 Minuten muss ich den Router neu starten.
Beachten Sie, dass:-
1. Ich habe auch direkt mit Kabel verbunden, es ist immer noch tot, also kein Wi-Fi-Fehler.
2. Das Problem ist ziemlich alt. Es erforderte 1-2 Neustarts am ganzen Tag, aber jetzt muss ich alle 15 Minuten neu starten.
3. Das Ticket wurde als abgeschlossen markiert, aber die Situation ist gleich.
Edit: @mangatmodi moved in to the right board, also ticket number removed
13 Antworten 13
reneromann
Can you please attach a screenshot of the line statistics if the connection is alive? Maybe the line is faulty and your router needs a reboot as it is not able to cope with the faults. The other thing could be a faulty router...
@reneromann
Thanks for the reply. Could you help me to locate the line statistics page? I am using Sagemcom FAST5460 router.  Is it at Router > Cable Modem > Connection
Yes...
Jens
Hello mangatmodi,
if you find the statistics, sent me also a pm with your customer data.
Regards
Jens
Edit: Ticketnumber removed.
@Jens @reneromann
I have sent you the line statistics when the line was not working. Note that the line led in the router either blinks slowly or totally get off when its not working. Otherwise we have a solid stable light
@Jens I have also sent you the private user data you requested.
Sorry guys,
Google translate is messing up the input I am typing. Basically I have sent line statistic to each of you.
Seems your line needs to be fixed...
The signal power level for the downstream is 10 dB too low and the signal level for the upstream is 6 dB too high - I would say that a technician should check the amplifier settings in your house.
Jens
Hello mangatmodi,
thanks for you pm with the statistic. But i can't see your cablerouter. Did you hook him up to the power?
Regards
Jens
Yup, the router is plugged into power. It simply disconnects from outside world after few minutes/hours. That time is inconsitant.
