VPN blocked
Vladas
Hello!
Due to COVID I am working from home using VPN since March without issues, however since yesterday my VPN is no longer connecting. I am able to connect to VPN using mobile tethering or wifi from the office or a caffe, but not from home.
Has Vodafone started blocking VPN access for me? Please let me know what details you need from me to check this issue.
Kind regards,
Vladas
Moni_GK
Hello, Vladas,
we do not block VPN connections. Have you ever asked your IT department if they know of any errors?
Greetings Moni
Mav1976
Hi @Vladas,
What internet service are you using at home? Internet via DSL or cable?
Moni_GK
Hello, Vladas,
Greetings Moni
Yes, thank you. It could have been a weak signal from my KabelBox that was causing the issue. It got solved after I connected my personal router to the KabelBox.
Thank you all for the help!
