Router constantly rebooting
Evleo
I am facing a problem with my internet connection since yesterday. The router keeps rebooting almost continuously. It reboots, then all lights stay on except for the wifi that keeps flashing. So even when it is on the Internet connection is very flaky. After a few minutes the router reboots again.
Do you have any ideas?
Thank you for any help!
Evleo
Hi Fred,
Thank you for trying to support! A technician managed to come so the issue was looked into. Seems to be the external wiring!
Thank you for your help,
Evleo
ERFD
Ex-Moderator:in
Ex-Moderator:in
Hello, Evleo,
there seems to be something wrong with the signal. Can you please make a screenshot of the level values in the GUI?
Best regards Fred
Evleo
Hi Fred,
Evleo
ERFD
Ex-Moderator:in
Ex-Moderator:in
Hello, Evleo,
thanks for your feedback. I'll finish your contribution with it.
Best regards Fred
