am 11.09.2020 19:47
Dear admins,
today I have tried to install the modem from Vodafone for the new internet contract but unfortunately it doesn't work properly. The router is restarting from time to time and the Download speed is really far a way from the one in the contract. I did a few tests and the highest Download speed was 200 Mbps instead of 1000 Mbps.
I would need some advise from you about how this could be fixed quickly becuase otherwise I am also thinking to use the 14 days cancelation of the contract.
Thanks in advance
12.09.2020 08:15 - bearbeitet 12.09.2020 08:23
am 15.09.2020 12:14
Hello Silver2,
you can please give us the following information:
Many thanks and greetings,
Maria
am 19.09.2020 05:51
Hi Maria,
thank you for your feedback here. Just to quickly answer some of your questions I do have Red Internet & Phone 1000 Cable U, from your current offers. with router from Vodafone. The contract is new, for the 2nd week, and I am using Chrome and Windows 10.
However, after writing here I did a few more tests, LAN and Wifi and the conclusion is that my personal laptop has some hardware limitations, La up to 100 Mbps, and Wifi up top 400 Mbps. I did similar test on my work laptop and I measured more than 900 Mbps on LAN. Also my monile Huwawei P20 Pro measured up to 700 Mbps on Wifi. So I think that the internet speed is alright.
Btw, would you be able to check and confirm how I should make the payments, if I should send the activation fee with Sepa or Wire transfers ? It is not clear from their letter and emails. I could send youthe deatils on private.
Thanks
am 21.09.2020 08:07
hello Silver2,
I am glad that you have found the solution for the problem yourself.
Can you send me your data by private message?
Best regards
Luisa
am 21.09.2020 18:41
I have just sent you a PM. Thanks
