am 24.07.2020 14:36 - zuletzt bearbeitet am 26.07.2020 14:24 von DanyG
Hello, my internet have some problem, and I can only speak a little German, so I'm sorry for writing in English. My internet works pretty good before, but it suddenly can't work from 22th July, and I'm not sure is the problem of the router or line. The currently status is that there is no wifi signal of my router, and the light of internet on router is off, the power light is remain red. I've tried to plugged out the router and cable, then plug in after five minutes, and nothing changed.
I'll be appreciated for any help.
Best regards
Ying-Ying Zhang
Edit @Ying-ying Switched to the correct DSL-board. BR, DanyG
am 24.07.2020 23:55
welcome to the Community.
Are you sure that you have Internet over the TV Cable? The EasyBox 804 is for (V)DSL which is delivered over Telephone Line.
am 26.07.2020 14:27
Hi Ying-ying,
I've has a look on your line, but can't see any interrupts or a complete connection failure. What happens, when your EasyBox is connected via LAN-cable with your PC? Did you already try this?
BR,
Dany
am 26.07.2020 15:27
Hi, I alredy tried that, and there are no response on my computer (the status is no internet connect).
am 27.07.2020 14:01
Waiting... Can anybody help me?
am 27.07.2020 16:30
Hi Ying.ying,
as mentioned via private message I opened a trouble ticket for you.
The technicians will check the connection and get back to you by phone or SMS.
Regards,
Jens
