am
24.09.2024
21:10
- zuletzt bearbeitet am
25.09.2024
10:55
von
R4mona
Hello,
After moving to a new apartment in the same locality, I am facing a significant increase in internet interruption and very low speed on my devices. I moved to a new apartment and plugged into the same Vodafone router which I was using in my old house and was getting around 500-600 Mbps on wifi but now I am facing huge internet drops and only 20-30 Mbps speed on my devices which is not fair.
Please resolve this issue or send someone urgently as I have to work from home or let me know what I can do to fix the issue.
While running the test on https://speedtest.vodafone.de/ I got the results (attaching the photo). please also note while doing the testing I am sitting next to the router which means excellent signal strength.
Customer No. **************
Name - Jagkaran Singh
Vodafone router - CGA4233DE
best regards
Jagkaran Singh
Edit: @JagkaranSingh > Customer number and address removed due to data protection
am 25.09.2024 10:59
Hi @JagkaranSingh,
I’m really sorry to hear about the frustrating internet issues you’re experiencing after moving to your new apartment. 😢 It must be incredibly stressful, especially since you rely on a stable connection for working from home.
Given that you were getting excellent speeds in your old apartment with the same router, it sounds like there might be an issue specific to your new location.
Here are a few steps you can try to troubleshoot the problem:
If these steps don’t help, it might be best to contact us directly and explain the situation. Given the urgency of your need for a stable connection, they should be able to prioritize your request and send a technician to assist you.
I hope this helps, and that your internet issues are resolved quickly! 🌞
Kind regards
R4mona
am 18.10.2024 10:08
Hello,
On 07.10.2024, a technician visited my home where we recently shifted and he did not do anything but just connected and disconnected the cables and said the internet is working fine.
I am still facing a large number of internet disconnection on daily basis specially when i am working from home, please try to understand that my work is getting affected because of this internet disconnection issue.
I have tried everything you mentioned earlier in your comment but of no use and help.
I really urge you to send someone immediately and replace the router if that causing the problem because it's too old. The technician who visit the house must replace everything which is need for stable internet connection if not then i have switch my internet provider and that's really sad because i am a Vodafone customer from more than 3 years and you are unable to fix my internet issues 😞
am 18.10.2024 10:19
Hello @JagkaranSingh ,
this is not a nice situation for you. We can't post a technician job for you in the Community. You are welcome to do this via WhatsApp. Please contact us via this link👉 Dein Kontakt zu Vodafone - Vodafone Community.
We will be happy to take care of it so that everything is up and running again as quickly as possible.
Best regards
Ricky
