Hilfsangebote außerhalb der Community
  • Jetzt mit Tobi chatten Chat Jetzt mit TOBi chatten
  • Nutze unsere Hile bei Störung. Störung? Nutz unsere Hilfe bei Störung!
  • Entedecke unsere digitalen Lösungen und nutze sie Mehr? Entdecke unsere digitalen Lösungen und nutz sie!
Kabel 200mbit slow in the evening as more residents are moving in (Berlin)
csongor
Hello,
First of all, sorry for writing in English, my German is unfortunately not good enough.
I've been a happy customer of Vodafone, but as more and more people are moving in to the newly built apartment building where I live, in the evening the speed is getting slower and slower. At the moment instead of 200mbit/s, I'm only getting 77mbits in the evening (http://www.speedtest.net/result/7682689306) (which is not bad at all, but the tendency is that the speed I'm getting is decreasing over time as new residents move in, and I'm pretty sure that the speed will get lower in the future).
Can you please take a look at the utilization of my segment?
Kind regards,
Csongor
5 Antworten 5
Manu
Hi csongor,
I'd be happy to check for you if the workload's too high.
Will you please send me your name, address and customer number in a private message?
Please let me know when the message has been sent.
Best Regards, Manu
csongor
Hello,
The private message with the required details has just been sent.
In case the network utilization is too high: Is there any way to request a DOCSIS 3.1 capable router instead of the current one? The analog shutdown is going to happen on the 6th of November where I live, and an additional block of DOCSIS 3.1 frequencies are going to be available, which would probably make all the bandwith problems go away if I had a DOCSIS 3.1 capable device.
Manu
Hi csongor,
the lower bandwidth is not related to the new tenants in the house. There is a general load in your connection area. The colleagues are working on it, more capacities have to be created.
Best Regards, Manu
csongor
Thank you for your answer. Is there any timeframe when this problem will be fixed?
Also can you please answer my question about requesting a DOCSIS 3.1 capable device? The DOCSIS 3.1 frequencies enabled after the analog shutdown will provide more than 500mbit of shared bandwidth to the segment, but without a compatible device I cannot utilize it.
Manu
Hi csongor,
The work is expected to be completed by the end of November.
At your address there are currently no more than 200MBit/s possible. If the network is ready and 500 MBit/s are possible, then you can change the contract and get the appropriate router.
Best Regards, Manu
