Siehe neueste
Ethernet Connection
Nicht anwendbar
I've been a WLAN user since ever and now I have problem with slow connection. I tried yesterday to connect my screen with the router through Ethernet cable but didn't work. Do I need any configuration of IP settings ( Static IP settings ) for the screen ?
Thank you
2 Antworten 2
Ilja13
App-Professor
Take your WLAN off when you try to connect with cable.
IP Settings have to be DHCP - not static.
Maybe your cable is broken?
Nicht anwendbar
Maybe ... Thanks for your reply. I'll try another cable
