am 11.04.2018 12:32
am 12.04.2018 17:55
Hello Teresa,
we'll send a technician to install it. I can't see the modem online.
Your colleague will contact you by phone to make an appointment. I'm also writing for you to speak English. Please give me a feedback if the technician was with you.
Best regards
Lars
am 11.04.2018 18:27
Hi Teresa,
I'll check this.
Please send me your customer number, name and address by private message. Write short in the post as soon as you have sent the PN.
Best regards
Lars
am 11.04.2018 21:46
am 12.04.2018 17:55
Hello Teresa,
Best regards
Lars
am 13.04.2018 17:06
Hi Lars!
The technician came earlier today and solved the problem, the signal was too weak so he had to make some changes downstairs in the basement and needed to come upstairs with the meassurement device a couple times, he also had to install a new connector as the one that I had in the house was old and wasn't ideal for cable connections. Now everything works perfectly 🙂
As for the payment, I suppose it will be included in my next bill, right?
Thank you very much for your help!!
Best regards,
Teresa
am 14.04.2018 14:52
Hello Teresa,
i am glad that the technician was able to set everything up and your connection is now working. There will be no cost to you, the first installation is free of charge, even if a technician had to help you. 🙂
Regards
Grit
