[English] Improving Internet connection to certain IP
ValeriiVasin
Digitalisierer
Digitalisierer
Hey folks,
Recently i've been playing Online game that is pretty sensitive to connection drops. Unfortunately time-to-time i have quite often connection drops. I checked MTR to the game servers and it shows that no my game service is the one to blame, but rather Vodaphone.
I do have lots of package drops on static ip server address *.static.kabel-deutschland.de (23% loss) and on ip 145.254.2.179 (67% and 65% loss) - not sure what it is, but whois shows that it belongs to Vodafone.
The target IP address of my game is 109.105.133.32
I am not sure if i am able to post here full trace to it by WinMTR - that is why just piece of information that is creating problems...
If its not the right place to post such questions - please assist in finding the right one.
Thank you!
Connection is stable at the moment. In case of problems I will create another thread. Thank you.
10 Antworten 10
ValeriiVasin
Digitalisierer
Digitalisierer
I have found thread about the similar problem:
https://forum.vodafone.de/t5/Archiv-Störungsmeldungen/Paketverlust-im-Vodafone-Backend-145-254-2-0-2...
But it seems that there the reason was some other problem.
Here is the trace of my route where you could find crazy loses on one of the vodafone IPs:
IP addresses are similar to the problem in that thread. Please help to fix that crazy loss (60-70%).
pRo-Marco
Hi ValeriiVasin,
this is no real lost, else you would see it also at the target. It is kind of overload, so that the ICMP request gets no answer.
I think the problem is that there are ping-spikes. Reason for that is an issue in our infrastructure. Our technicians are about to solve this.
Kind regards
Thank you for the answer. I am looking forward to that fix.
Also I found another problem: DNS looping. I am not certain how to report that.
MacBook-Pro.local (192.168.1.149) -> 79.104.225.1                                          2020-12-30T10:44:55+0100
Keys:  Help   Display mode   Restart statistics   Order of fields   quit
        Packets               Pings
 Host        Loss%   Snt   Last   Avg  Best  Wrst StDev
 1. 192.168.1.1 (192.168.1.1)                                            44.3%  6002    1.3   2.7   0.9 234.7  12.3
 2. 192.168.0.1 (192.168.0.1)                                            44.3%  6002    4.4   4.8   1.9 495.9  15.7
 3. ip53a9b72d.static.kabel-deutschland.de (83.169.183.45)               21.3%  6002   14.2 275.3   8.1 11999 17456
 4. ip5886eac9.static.kabel-deutschland.de (88.134.234.201)               0.3%  6001   21.0  20.5   7.9 447.5  21.2
 5. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.3%  6001   18.6  21.0   7.8 417.0  21.6
 6. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6001   10.9  21.1   7.5 396.9  21.9
 7. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.3%  6001   21.9  21.4   9.0 361.9  22.3
 8. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6001   24.6  21.6   8.5 412.7  22.6
 9. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.3%  6001   18.1  21.8   8.5 380.7  22.8
10. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6001   16.7  22.4   7.6 1480.  30.6
11. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.3%  6001   17.9  22.2   8.2 1588.  31.1
12. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6001   24.6  22.7   8.3 1554.  31.3
13. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.3%  6001   22.0  22.7   8.4 1517.  30.4
14. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6001   14.7  22.6   8.7 1479.  29.7
15. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.3%  6001   20.5  22.9   9.2 1445.  30.5
16. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6001   16.5  22.5   9.3 476.6  24.1
17. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.3%  6001   22.0 -74.5 -5980 440.5 7733.
18. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6001   18.8  22.7   9.0 495.1  23.9
19. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.4%  6001   19.8  22.7   9.7 623.0  23.9
20. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6001   17.9  22.7   9.5 594.5  24.2
21. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.3%  6001   40.2  22.8   9.4 590.3  24.4
22. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6001   21.3  23.1   9.2 1296.  30.1
23. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.3%  6001   21.2  22.8   9.3 585.4  25.4
24. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6001   20.7 -236. -1567 548.2 20265
25. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.3%  6001   16.3  22.8   9.4 513.8  24.1
26. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6001   21.3  22.7   9.4 476.4  23.3
27. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.3%  6001   21.5  22.8  10.0 441.7  22.8
28. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6001   19.4  22.8   8.4 542.1  23.3
29. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.3%  6001   16.0  22.6   9.1 507.0  22.4
30. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6001   33.5  22.7   8.5 574.1  22.6
MacBook-Pro.local (192.168.1.149) -> 79.104.225.33                                         2020-12-30T10:47:35+0100
        Packets               Pings
 1. 192.168.1.1 (192.168.1.1)                                            50.2%  6175    1.0   2.9   0.8 210.6  12.5
 2. 192.168.0.1 (192.168.0.1)                                            51.1%  6175    2.5   5.3   1.9 431.2  17.0
 3. ip53a9b72d.static.kabel-deutschland.de (83.169.183.45)               21.7%  6175   17.5  20.8   8.4 418.9  21.9
 4. ip5886eac9.static.kabel-deutschland.de (88.134.234.201)               0.3%  6175   22.3  20.7   8.1 382.1  21.8
 5. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.3%  6175   19.4  21.1   8.9 359.0  21.9
 6. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6175   35.3  21.3   8.1 401.4  22.7
 7. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.3%  6175   17.8  21.5   7.9 379.7  23.3
 8. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6175   14.0  21.8   8.8 345.0  23.0
 9. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.3%  6175   19.6  22.1   9.0 1309.  28.5
10. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6175   16.6  21.9   8.9 429.5  23.4
11. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.3%  6175   13.8  22.1   9.2 498.2  23.1
12. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6175   16.1  22.3   8.6 523.4  24.2
13. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.3%  6175   21.5  22.1   8.4 585.7  23.2
14. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6175   13.0  21.8   8.5 453.7  21.8
15. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.3%  6175   18.6  22.1   8.4 497.9  23.0
16. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6175   19.8  22.3   8.4 550.6  23.5
17. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.4%  6175   23.6  22.6   8.6 597.3  24.0
18. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6175   19.6  22.7   9.7 592.1  26.1
19. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.3%  6175   16.4 168.9   8.6 89960 11466
20. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6175   17.4  22.7   9.5 585.5  25.2
21. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.3%  6175   16.9  22.9   8.7 547.9  26.0
22. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6175   15.4  23.1   9.1 513.7  25.1
23. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.3%  6175   16.9  22.8   8.3 475.2  23.8
24. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6175   18.6  22.3   8.9 449.0  22.5
25. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.4%  6175   22.0  22.5   8.7 537.4  22.9
26. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6175   16.9  22.4   9.1 509.5  23.8
27. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.3%  6175   16.3  22.9   9.8 1484.  30.1
28. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6175   20.2  22.8   9.0 1588.  30.7
29. ip5886edb5.static.kabel-deutschland.de (88.134.237.181)               0.2%  6174   21.4 -71.7 -5980 1554. 7621.
30. ip5886edb4.static.kabel-deutschland.de (88.134.237.180)               0.3%  6174   17.3  23.0  10.3 1517.  29.7
It looks like that something is down and packets can not go through.
P.S. Recently (last 7 days or so)  I do not have big problems with the package drops in my game (I do really hope that you guys fixed that and it is not coming back again soon).
P.S.S The problematic IPs got provided to me by the Golden Telecom (gldn.net) who is on the way to my destination point.
ERFD
Hello ValeriiVasin,
feel free to look at it again in the next few days and then please give us another feddback so we can close your post.
Best regards Fred
After 17th of December connection seems to improve a lot.
But still, I do see a lot of ping spikes and drops (probably ICMP drops) on the 2nd hop (presumably something in the house, or nearby). You can find the connection logs from PingPlotter here. And it does not seem to be healthy and affects connection quality.
Also there was complete connection drop today at 1.23-1.33pm (Berlin time). Logs here. Surprisingly - even the router seems to be not available during that time, even though all the 3 lights were active on it that time.
Jana478
Administrator:in
Administrator:in
Hello ValeriiVasin,
I need the complete ping plotter measurement please, unfortunately what you sent is of no use to us. Please use a LAN connection for this.
Kind regards
Jana
what do you mean by "complete ping plotter measurement"? I sent complete measurements at that period of time.
Here is one more from today - complete internet absence for more than an hour (21.05 till 22.15 Berlin Time):
https://share.pingplotter.com/2UpZrWLJpmm
pp2 file could be downloaded and viewed from there.
All the measurements done by direct connection (not wifi).
Also what is the way to figure out if Vodafone is having some problems and working to fix them? is there a status page for my house/contract or smth? In cases of complete Internet shutdown I am blind and do not know when its going to be fixed nor what happened. Vodafone also does not notify afterwards why in Prime time (Friday evening) I was not having Internet for more than an hour.
Not sure why it says that router was not available - it was rebooting couple of times, and pingable from terminal, but here it was refusing to reply it seems. So I guess there was some problem near my house that starts from the second hop (83.169.183.45).
Jens
Hey ValeriiVasin,
the content of the test is better, but the result is not.
Please make a screenshot so that the interval is also visible.
Can you also give times when it is better? So that there is a comparison.
Regards
Jens
