am 17.12.2020 21:50
Dear Vodafone Team,
Although my router has been replaced by the technician, I am experiencing numerous disconnection problems throughout the day. These disconnection problems occur while using both of cable and Wi-Fi. In case of disconnection, there is no change in the lights on the modem. In this period when we work from home, this has become an ordeal and our business is negatively affected.
I kindly ask you to fix the problem as soon as possible.
Best Regards,
Deniz
18.12.2020 12:30 - bearbeitet 18.12.2020 12:31
am 23.12.2020 08:09
Hello Deniz34,
I see that on 28.12.2020 a new on-site appointment takes place, then the technician looks at it again.
Best regards, Martin
am 28.12.2020 12:31
Dear Martin,
The technician just came in order to fix the problem. I do have some remarks as follows:
1. He replaced the router with a new one, stating that the Wi-Fi connection problems were caused by the router. This is the second router change as I mentioned earlier. Although I don't believe it, I hope this is a permanent solution.
2. After completing all the operations, he performed a speed test by usigin his terminal. The speed results were not stable and were between 450-850 mbit. Of course I cannot see the internet speed above 350mbit on my computer. Why do I have to pay this money every month for the promised speed values that I cannot use?
3. When I entered the router home page to make the necessary settings, I realized that the firmware version is "01.01.117.01.EURO". What problems have been solved on this device belonging to the old firmware version? The technician shared that this router is the latest manufactured model and the problems have been solved.
4. As far as I know, the guest wi-fi option is not active in this version. When can I automatically get the latest version to use this feature?
Thank you
Deniz
am 02.01.2021 14:33
Hello Deniz34,
I guess we will find out if the new router works only after a while.
If the technician has reached between 450 - 850 MBit in his measurements, but you only 350 with your device, then please check the settings on your laptop if necessary. You should be able to get at least over 350 Mbit.
The routers that are installed do not have the latest firmware right from the start. I see that your cable router has already received the new update.
