am 03.05.2018 18:10
I bought a 30-day ticket on April 16th and it worked for about a week (of course with little problems - it worked 1-2 hours and then 10-20 minutes break) and now it does not work at all.
The Hotspots near me are:
HH-3-3226218
HH-3-3226802
HH-3-3500511
HH-3-3255545
HH-3-3239342
am 09.05.2018 08:26
I have rebooted the router. The connection to your laptop should work.
Regards
Wallace
am 09.05.2018 11:11
am 11.05.2018 07:56
am 11.05.2018 08:47
well, do you try to connect to a "Homespot" or "Hotspot"? On your screenshots you could clearly see you try to connect to a homespot. You cant use a homespot with hotspot flat, the flat is just for these hotspots.
Regards
am 11.05.2018 09:04
am 12.05.2018 08:22
am 12.05.2018 10:14
Hello Ionut1,
please send me a phone number so I can make a task for the second level. The colleagues will check everything from our side and try to solve the problem with you. Don't forget to reply here after you sent the number.
Kind regards
am 12.05.2018 11:53
am 13.05.2018 22:40
Hallo?
am 14.05.2018 13:34
Hello Ionut1,
because the colleagues will probably need to call you to solve the problem.
Kind regards
