Terminate Vodafone Kabel Deutschland contract
vasilis
Dear forum,
I want to terminate my Vodafone Kabel Deutschland contract. Will you please tell me how?
Thanks,
Vasilis
Grit
Hello Vasilis,
i've given you notice of termination and I'll send you a confirmation. Unfortunately, it was not enough for a termination this year.
That's the best I have for you. Colleagues may report to the recovery department when the contract ends.
Regards
Grit
5 Antworten 5
Grit
Hello vasilis,
have you already tried to cancel using the contact form?
May I ask why you want to resign?
Regards
Grit
vasilis
Hi Grit,
Thanks for your message. I actually did use the form after I found the link in this forum, and I got the message from Vodafone support to get back to the forum and raise a question, so here I am. 🙂
I want to resign as I see better options available in the market and vodafone is not really willing to do something about it.
Please let me know how I should proceed.
Best,
Vasilis
Grit
HelloVasilis,
i can only terminate your contract normally at the end of the term. I need your name, address and customer number. Send me the data together with the link to your contribution in a private message and then contact me again here.
Regards
Grit
vasilis
Hi Grit,
It's done. Will you please send me a confirmation?
KR
Vasilis
Grit
Hello Vasilis,
Regards
Grit
