Change to lower tariff
evghenix
Hello!
Back in March 2020 I was contacted by a Vodafone represent with an offer to try the "Red Internet & Phone 1000 Cable" with possibility to switch back to my previous tariff in one year. So, I've tried it and I would like to go back to my "Red Internet & Phone 500 Cable". Tried to do this online on https://www.vodafone.de/meinvodafone but the available options are only to get even bigger tariff. How can I get to my previous tariff?
Nancy
Hello evghenix,
I have completed the switch to Red Internet & Phone 500 Cable for you on 20.03.2021. You will then receive another confirmation.
Best regards
Nancy
Grit
Hello evghenix,
it doesn't quite work as you write. You cannot change to the tariff you had before the contract change. If you want to change to 500 Mbit/s, you will find the conditions for this in the order confirmation. You cannot make this change yourself. I'd be happy to help you with that, though.
Send me a private message with your name, full address, customer number and date of birth. Important: Report back here in the thread afterwards.
Regards
Grit
evghenix
Hello Grit!
Thank you for the answer. Private message has been sent.
Regards,
Evghenix
Nancy
Hello evghenix,
Best regards
Nancy
