am 20.11.2019 12:33 - zuletzt bearbeitet am 21.11.2019 11:43 von DanyG
I need some english help. I changed my apartment, and I would like nmove my internet to the new apartment.
Thanks a lot!
Edit @pabloruedamolto: Moved thread to the correct board. BR, DanyG
am 20.11.2019 17:30
am 21.11.2019 10:53
Cable 100 @Mav1976
21.11.2019 11:49 - bearbeitet 21.11.2019 11:52
Hi Pablo,
you're gonna have to report a move. You can do this using the move form. There is a department that is only responsible for removals. You will receive the form and process the move. You don't have to write much in German, just give the customer data and the new address.
Regards
Grit
Edit: Please don't just write the moderators in DM unless you are asked to do so.
