Internal DNS server problem
Geshkin
Hallo.
I have a problem with connection at evening time (mostly after 5 pm). The speedtest and ping (also ping to direct external IP address) are good. But Ping to some external hostname (like google, or any other) may takes up to 10 seconds.
I use Vodafone staion 6444. Tired over WiFi, LAN, from various PC, form new just installed OS. The result is same.
For sure it is not a cookie or browser problem. It is Vodafone DNS server problem.  How to fix it?
I do not able to change nothing in the Vodafone station settins.
MuratAydin
I have a similar problem. When I open a website, initial connection takes so long. When connection is established, website is downloaded and displayed very fast.
