am 22.05.2020 12:52
Hello,
I have just upgrade my connection to 1000MBit. currently I got "Dan CH7466CE" as a modem, do I need to replace it?
am 26.05.2020 08:15
Good morning Dejablue79,
yes, you need another cable router. If you have already ordered the tariff switch, the hardware change should be ordered automatically.
Best regards
Tina
am 26.05.2020 08:15
Best regards
Tina
am 05.06.2020 17:52
Just in case: You will also need appropriate gigabit-capable network cards and LAN cables (Cat.6 / Cat. 7) for your end device (..../computer).
