English Speaker. My internet has been disconnecting frequently
LuigiGF46
Sorry for writing in English.
For the past Week I have been having problems with my internet, my Fritzbox disconnects at least once a day, and in the past 2 days it has happened many times.
Never had this problem over the last 3 years (more or less) since I have this connection.
Is there anything I can do? or there is some problem with the coverage?
Best regards.
Luis
LuigiGF46
Hi Jens,
you can close it. Seems like it was a temprary issue.
Best regards
Luis
4 Antworten 4
Jens
Hey Luis,
is the FritzBox from Vodafone or is it one of yours?
Can you give me a time when it's disconnected?
Have a look at the menu and check the signal data. Post a picture of all the signal-data.
Regards
Jens
LuigiGF46
Hey Jens,
Meanwhile the connection has been stable so far since saturday night, if problem comes back I will get back at you.
Thanks
Regards,
Luis
Jens
Hey Luis,
that's ok and thanks for the short feedback.
You wanna watch this some more or can I close up here?
Regards
Jens
LuigiGF46
Hi Jens,
Best regards
Luis
