Cable router TG3442DE
Dr_Natalia87
Dear all, sorry for writing in English.
I would kindly ask you for a help!
I have problems with my cable router Vodafone TG3442EN: LAN internet connection works; but there is no WiFi connection; WiFi botton does not work and the light above WiFI botton is not even if you are pressing the botton or not. WPS light is off WPS botton does not help.
I reloaded router for several times, but it did not help. The only thing I did not press "reset" as I can not be sure that this is a right solution.
Unfortunately I could not reach out to the service via phone (08005266625) because the line was always busy.
Please, navigate through the further steps. Perhaps, I need help of technitian.
With best regards, Natalia
ERFD
Hello, Dr_Natalia87,
I like looking at your modem. Can you please send me your customer number, address and date of birth by private message?
Best regards Fred
chattop2
Rookie
Rookie
Hi Natalia,
We are having similar issues. Did you manage to resolve your problem?
Thanks
Soumya
does your contract include the wifi option?
